Old 07-13-2023, 05:05 AM   #24
Franco
Franco's Avatar
Originally Posted by Need_for_speed View Post
I asked about the blowing bottle noise issue on the PCA tech forum and someone answered that it was probably the valve housing in the front right fender: 996 201 231 01. This part is the housing for the two valves I replaced earlier this spring to try and resolve the issue. I know one of the valves controls flow to/from the carbon canister.
Apparently, this valve housing was a known issue and a TSB for 996 models several years ago. Of course, the part retails for around $500.
So...before I empty my wallet, is there any forum experience regarding this part? Any idea what exactly could fail in the housing that could cause the noise (rubber seal, etc.)? It looks like one of the two lines leads to the grommet opening in the fuel filler door, so my hunch is that the housing has failed in such a way that the associated valve is unable to properly seal this line.
Need For Speed thanks for all the info you provided us.
I have the same problem and was wandering if you resolved this problem and if so may you share the solution with us please.
1997 Porsche Boxster manual
2018 Subaru WRX Sport Tech
2014 Honda CRV
2014 Mercedes Benz 350 ML
2015 Chevrolet Corvette Stingray manual
Franco is offline   Reply With Quote
