Old 06-28-2023, 06:42 PM   #1
JohnENC
I have one headlight out. Wires all look good, pin connections in the back of the headlight module and at the plug in the tunnel all look clean. Fuses are good. Is the headlight switch fused, and therefore has separate connections for L/R lights because each side has its own fuse (or if the switch is bad, would both sides be out)?
JohnENC is offline   Reply With Quote
