Old 06-16-2023, 11:35 PM   #1
99boxster986
Corrosion on the wiring harness to the immobilizer is a possibility, are there any cleaners or methods that you recommend for getting that cleaned out? And I hear you about checking all the fuses and relays. As for the starter relay that just came in today. Weirdest thing. I installed it, and it doesn't even want to turn over. But when I jump the pins for the relay, turns over but doesn't start. Shouldn't it turn over with my new relay since it works when it's jumped? I'm so confused on that part....
99boxster986 is offline   Reply With Quote
