Old 06-15-2023, 03:06 PM   #1
robmints
Fixing The Start Up Rattle
Hi guys. All help appreciated.
01 base. LN ceramic IMS no oil line. LN oil filter base.
Bank1. 7.1
Bank2. 4
Start up rattle that is a bit transient and not on all cold starts, or long periods of sitting. Can happen any time. Most common cold but not necessarily. Does happen more often now that I got a new battery.
In my Pelican cart I have all 3 tensioners w/crush washers. New guide rail with pad/ clip/ bolt oring. 2 FU/RL ramps. 2 FL/RU ramps. 2 sets of vario cam pads. Another guide rail for the intermediate shaft. 6 End Plugs. Will get 5900 from store. I have the Baum kit for timing.
A couple of questions.
Do I need more info from durametric on solenoids or actuators?
How do I know if i have 5.3 or 5.7 abs? No psm on the car. Durametric is asking me at set up.
Can I get all the chain guides swapped with the engine out and valve covers off?
What book or directions should I buy? As you can tell i am only youtube trained so far.
Thank you!!
robmints is offline   Reply With Quote
