Old 06-12-2023, 09:18 AM   #24
nuvolari
I have a '97 and '01 engine that I can pull the bearings on later this week. Not sure which bearing the '01 has and the flywheel is still on, but there's a good chance I can salvage the clip from the '97.
Hey, thanks a lot, I would appreciate it, that would be great! No rush as I'm just getting started putting this engine back together after a year and a half, argh. And I'm still trying to locate a source for a new ring but the suppliers I found are manufacturers so they don't usually stock or sell these rings individually. Still more research to do.
Hey JFP, have you ever had trouble and destroyed the retaining ring when removing a bearing? Just wondering what went wrong. I thought maybe I did something to the ring when using the homemade tools to extract but I don't think the ring was or could be damaged until it's out of the groove and approaching the extraction tool tube and this never happened until I used the LN tool. I did try to center the tube and to minimize the chance of this happening. Also, I figured the beveled edge of the tube and LN design would avoid any binding. Or maybe the ring was damaged when originally installed; that might explain the trouble I had with the homemade tools. Any ideas? (Just curious at this point....)
00 986S
86 944 Turbo
87 VW Scirocco 16v
87 Alfa Romeo Milano
77 Alfa Romeo Alfetta Sedan
nuvolari is offline   Reply With Quote
