Old 06-11-2023, 06:13 PM   #24
nuvolari
***I looked back at your post and realized I misunderstood. The clip in the Pelican Parts kit does look wider and on the dual row engines holds a spacer in place rather than fitting into a groove in the bearing.
Ah, thanks for that info and that makes sense as the Pelican bearing is single row. And I was planning on buying the pelican kit but now I'm not sure if the center bolt will be compatible with the OEM dual row bearing.
Does anyone know?
Yes, I reused the original cir-/wire clip, as mine wasn`t damaged. The bearing I used was different from the factory NSK bearing, I actually used two bearings and machined the groove on one of them at the same exact position as the original.
Oh, yes, I remember reading your thread now.
Originally Posted by elgyqc View Post
Yes I reused the original clip.
Thanks for the reply.
Does anyone have a clip out of their dual row bearing laying around after installing a new bearing? I would love to buy one from someone.
00 986S
86 944 Turbo
87 VW Scirocco 16v
87 Alfa Romeo Milano
77 Alfa Romeo Alfetta Sedan
nuvolari is offline   Reply With Quote
