Old 06-08-2023, 06:52 PM   #38
Radman
I know that JFP in PA has posted in a couple threads about how to flush the engine to get any residual pieces out. It is possible for them to block coolant passages and create problems if they remain.
Note for reassembly: The two bolts that are longer go in the holes with the dowel pins. Use a coated metal gasket (probably included) and no sealant. Torque 10 nm/7 ftlbs
Yep! Thank you for the backup just in case. Just buttoned the whole thing back up but will follow up with JFP to be safe. Worst case I have to order new gaskets or something.
Radman is offline   Reply With Quote
