Old 05-29-2023, 09:50 AM   #3
MR2Aaron
You might try hosing the whole thing down with brake cleaner until it's pretty clean, and then drive it a little, and see if you can spot where the oil is coming from then, when it's not just coating everything.
A leak at whatever seals that IMS bearing doohickey is also a possibility.
MR2Aaron is offline   Reply With Quote
