Old 05-12-2023, 11:23 AM   #1
Stevo009
Cranking with no start 986
Hello all,
I have a 2000 Boxster S. Yesterday morning car cranked an unusual amount of times before starting. Drove fine until work 15 miles later where I parked it for 10 hours. After work cranked an unusual amount of times again before starting this time with it being semi rough during the startup process. It ran perfectly fine all the way to the gas station. After getting gas car would crank and crank and no fire up. Initially it almost started but eventually wouldn't come close to firing up just cranking. I had it towed home and is now in my garage. I smelled gas after cranking a bit. Battery power seems strong. The other day prior to this all I think I noticed when I was rolling into my garage the rpms dropped a tiny bit for a second. Other than that no noticeable performance issues. Car has full tank now but had low gas before gas station. I'm reading all possible things between, crankshaft positition sensor to fuel pump to spark plugs just hoping I could be pointed in a correct direction. No check engine lights.
Stevo009 is offline   Reply With Quote
