Old 04-23-2023, 06:01 PM   #11
blue62
Originally Posted by LoneWolfGal View Post
It's hard starting only after fueling, no other time. Yes, flooring the gas pedal does help to get it running.
I would go thru the EVAP system.
If flooring the gas pedal helps get it started then that points towards a too rich mixture when cranking. Flooring the gas pedal opens the throttle body butterfly allowing more air to enter.. so that leans the mixture out and helps get it started.
Now this is all guessing on my part so bear that in mind.
So look for things that could possibly cause a too rick starting mixture.
EVAP issues can do that... things like a stuck open purge valve or vacuum leaks in the hoses that connect up parts of the EVAP system or a cracked charcoal vacuum canister.
You can check the vacuum hose to the fuel pressure regulator as well (simple to do) but I do think if that was the issue it would cause problems a more times then just when you refuel.
