Old 04-18-2023, 08:44 AM   #12
Homeoboxter
Originally Posted by sfkjeld View Post
Been there, tried that. CA smog stations can tell the code has been cleared. The equipment will not pass a car with a cleared code.
Of course it won`t pass, because the readiness sensors show up as uncomplete. The codes need to be cleared AND the readiness sensors need to show completion. If these two conditions check out (and the error code won`t return) the car will pass. So the question is how long it takes for the code to return. If it returns immediately the car will obviously fail. If not, it`ll pass. You can monitor that with any generic tester, so you will know in advance.
