Old 04-12-2023, 12:56 PM   #21
ecp
Originally Posted by ike84 View Post
Dude, I remember your car now... You posted pics after the wrap and a bunch of ****************************s gave you **************** about the matte black, right?
I think it's a sweet car myself. Not factory, but very sharp and very unique. That's what custom stuff is all about!
I would take the insurance money, patch her up (you're clearly skilled), and see how much longer she will go. Yes, things will continue to break. Id be curious about a compression test - 140k miles is a lot for any gasser.
Blue is right about the ecu grounding comments - the ecu itself is grounded but it monitors the voltage on the ground to serve as a reference for the grounds that feed into it. That way, sensitive electronics (maf sensors included) that have small variations in their signal voltages due to electrical fluctuations can be "sorted out" by the ecu. It's kind of like running a ****************ty pic through a filter.
However, for the maf sensor, it really doesn't matter too much. In open loop fueling the dme ignores the maf altogether, and in closed loop fueling the narrowband o2 sensors trump the maf input. Sure, the maf readings do matter, but only so that the ecu can ballpark the conditions onto the fueling maps. If it's completely out of whack then it will cause issues, and that is why you saw trouble when you were grounded to the block - there is way too much electrical interference there. But grounding to the chassis is more than likely good enough for just driving and enjoying the car.
Never forget... The enemy of good is better
Sent from my SM-N975U using Tapatalk
Haha fortunately I’ve never posted my car and had any smack talk about it. Seems like the car will be able to be fixed and not totaled out. Bill is $6300 but covered by insurance. I’m planning on just driving it like I have been, it’s been a good car with a few hiccups here and there. Needs some rear wheel bearings and the rims have been bent which has been bugging me so I’ll want to sort that out. Maybe some 18 inch turbo twists would look cool.
I did a compression test like two years ago and if I remember correctly it was 160-165 psi all the way around with the throttle plate closed which from whatever I was reading at the time looked good.
ecp is offline   Reply With Quote
