Old 04-07-2023, 02:19 PM   #6
DaveRad
If you ran the car with the MAF unplugged or had the Key on with the MAF unplugged you will get the P0102 code.
If you didn't do that then the MAF is suspect...a bad MAF can also cause your other codes.
so I would replace the MAF clear the codes and see what happens.
If you replace the MAF replace it with a Bosch these cars don't like after market sensors for some reason.
Keep us posted on results please...
Sounds good, will do. Thank you very much. I’ve read that the MAF’s are very specific for the year, do you know which one I can buy?
DaveRad is offline   Reply With Quote
