Old 04-05-2023, 01:23 PM   #2
Kice
Long before aimlessly throwing parts at it, why not check and see if the DME is getting a signal from the CPS? Trace the CPS wires to the connector at the DME and look for a low voltage signal on them at the DME end when the engine is turning over; if you have a signal, it isn't the CPS.
Thanks! Is there a chart for the pins in the DME plug? Or is it best to go by the color coded cables from the CPS?
Kice is offline   Reply With Quote
