Old 03-29-2023, 09:21 AM   #20
djw8282
djw8282's Avatar
The fuel pump relay is in a relay panel left side foot well above the fuse panel.
Fuel pump relay is #13
The injector..ignition relay is in a realy panel in the rear trunk on the right hand side behind the dress panel.
that relay is #2
If you don't know how to use a multi meter to test a relay it is less trouble to just replace them.
They re not expensive.
If you replace them then we know for certain they are not the problem.
Oil type air filters are not good for MAF sensors.
Ok. I'm going to test/replace the relays then I will get back to you when done. Thanks!
djw8282 is offline   Reply With Quote
