Old 03-25-2023, 10:55 AM   #20
deemce1
Ok so not a ECU/DME relearning issue.
When you have the car running does it backfire??? miss?? anything like that???? Nothing like this.
When it dies is it just like it is running out of gas???? Yes - just dies. Tach drops to zero. or something different???
The reason I ask that is:
If the car was stored with fuel that contains Ethanol...Ethanol is Hygroscopic (draws moisture from the air)....so your fuel could have water in it. If the car is missing,backfiring, acting weird while it is running then that could be the issue.
If the car was stored with Non-Ethanol fuel and the car runs fair for the few seconds but just seems to run out of fuel when it dies....
Then that seems more like just a fuel delivery issue.
I am on my computer multiple times a day so I will check back and see if I can help you out.
I should note that if I blip the gas pedal it does not like that and dies quicker. Almost like when you try to give a motor gas with the choke on full (snow blower reference).
deemce1 is offline   Reply With Quote
