Old 03-25-2023, 10:46 AM   #19
blue62
Originally Posted by deemce1 View Post
Battery did not go dead. I had it on a Porsche charger while in storage.
No CEL on.
I will clean up the fuel injector relay now and report back. Thanks for the return replies
Ok so not a ECU/DME relearning issue.
When you have the car running does it backfire??? miss?? anything like that????
When it dies is it just like it is running out of gas???? or something different???
The reason I ask that is:
If the car was stored with fuel that contains Ethanol...Ethanol is Hygroscopic (draws moisture from the air)....so your fuel could have water in it. If the car is missing,backfiring, acting weird while it is running then that could be the issue.
If the car was stored with Non-Ethanol fuel and the car runs fair for the few seconds but just seems to run out of fuel when it dies....
Then that seems more like just a fuel delivery issue.
I am on my computer multiple times a day so I will check back and see if I can help you out.
