Old 03-16-2023, 01:37 PM   #2
Bush Pilot
Originally Posted by tcoradeschi View Post
If you want to remove the intakes (for whatever reason), start by reading your Bentley more carefully. All the information is in there.
The fact that you didn’t use the manual to locate the temp sensor in the first place is concerning. The fact that you thought that a flashing temp warning light indicates a bad temp sensor is also concerning.*
To be blunt, if you don’t understand the instructions, then maybe the job is over your head, and you need to accept that.
*Flashing temp light indicates low coolant level. You don’t even need the Bentley to learn that, the info is in the owner’s manual.
To be fair, I don't see instructions in the Bentley for the intake removal while the engine is in the car either.
Bush Pilot is offline   Reply With Quote
