Old 03-15-2023, 08:18 PM   #2
elgyqc
elgyqc's Avatar
Originally Posted by 986RennWagen View Post
Curious, what is the total clearance needed to drop the engine? Dropping a 914 engine is a piece of cake, figured this would be a similar process (more to unbolt, obviously)
Your are right there is a lot of stuff to disconnect. If you have a lift the actual engine removal is not too bad, my problem is that the Quickjacks, that are great for most jobs, come up just a bit short for wheeling the engine out. If I remember it is the bolts where the diagonal reenforcing pieces attach that are the lowest point.
I don't remember what the necessary clearance is... but is a couple of inches more than the lift of a Quickjack 3500.
Grant
