Old 02-26-2023, 05:29 AM   #1
Starter986
1998 Boxster Silver/Red
Thank you, 78.
New it shall be. So...
Hamberg Technic... or the Rein? There's a difference of about ~$75 for the pair with which I'm OK.
I'll wait on your recommendation then ordering the pair you choose. Hamberg or Rein? Thank you.
Also... I know that removing my existing mounts from the brackets is going to be a pain... and am considering having a shop remove the old ones (unless you have a removal recommendation?). Do you think I should source a pair of brackets? I then would remove from the car the existing brackets and mounts... install the new mounts to the sourced brackets... plug them in... and toss the old?
I appreciate your input. Thank you.
1998 Porsche Boxster
