Old 02-14-2023, 01:17 PM   #19
nuvolari
No idea. But this is what kind of damage metal impellers cause when the blades hit the case:
Hey JFP, and is the problem then that with the gouging now, the new pump won't flow coolant as well due to the clearance or is there a danger of the pump grinding into an oil passage or other leak? And how does this damage manifest itself in the future? Overheating? How long does this type of damage take to occur on a failing pump? I realize there are variables but just trying to understand if once it starts, the driver can hear noise and react or does it happen too quickly to react or so slowly that nothing is heard?
Also, how likely are the broken off plastic impeller bits to cause problems in the cooling system? And if so, what is the cure to removing them for shops such as yourself? (I dread to think but still would like to know the solution if any, whether it's a flush or requires engine disassembly that is not cost effective.)
Many thanks.
00 986S
86 944 Turbo
87 VW Scirocco 16v
87 Alfa Romeo Milano
77 Alfa Romeo Alfetta Sedan
nuvolari is offline   Reply With Quote
