Old 01-31-2023, 03:48 PM   #1
986mane
With that many miles I would be looking towards the MAF sensor as the possible cause of your issue.
Also a vacuum leak can create the same issue.
You also have e-gas which is electronic throttle.
So if you have disconnected your battery or had a dead battery you need to recalibrate you throttle.
Thanks I valeted the car and the valet driver left the lights on and windows down I got to the car it was dead. I got it started haven’t had the issue since mind you it’s only been one day and it is very random some times it happens some times it doesn’t. Do you know what I can do about the screen in the middle that shows my odometer it is like melted
986mane is offline   Reply With Quote
