Old 11-09-2006, 08:42 AM   #2
bmussatti
Guest
Posts: n/a
Originally Posted by tomk17
I just got a new 06' 987 in Seal Grey and the clear markers would definitly look better. I'm pretty technical and can certainly handle the change-out but what's involved? Looks like you need to remove the wheel well liner to get behind the light to release the lens. Is this a hassle or am I mistaken and everything can be done from the outside? A quick overview of the process would help from one of you guys who has done this.
Tomk17, you do not need to remove the wheel well's liner!. It takes about 3.47 minutes to pop-out & pop-in per sice. Pull the edge of the amber lens from the wheel forward towards the front bumper, disconnect the amber and then re-connect the clear, install in reverse order by setting the edge nearest the front bumper, and then pivoting back into place with the edge by the wheel well.
