Old 12-18-2022, 05:53 AM   #2
MAXF1net
Originally Posted by boxxster View Post
You're going to have to get to coilover from the top of the car.
Pages 19 and 20 here should give you an idea.
http://bd8ba3c866c8cbc330ab-7b26c6f3e01bf511d4da3315c66902d6.r6.cf1.rackcdn.co m/PDF_16119_Porsche_986_ECS_Adjustable_Coilover_Kit_ Installation_R1.pdf
Thanks, I have found them.
Front is easy accessible, removing the plastic caps in the front trunk and rebound can be easily adjusted.
Rear is problematic, you have to move up the roof up so the 'wing panel' moves up and then you can see the top of the rear strut - BUT, it has minimum clearance to the metal panel above it so it is impossible to put adjuster or any similiar key between.
Only solution is to pierce a small hole above the top of the strut and adjust from there.
I will post a picture when I do it.
Today I have tried the car with very stiff front rebound (it goes from 0 as hardest) to 22 as softest, I tried 4) and the difference to previous softer settings is huge - before, car was floating at high speeds on country road (130-160 km/h), now it is so planted and calm, much more control, especialy during the direction change...but it reacts harsher over the bumps. I'm glad the difference can be felt
Bump (compression) settings don't affect the car behaviour so dramaticaly, but it still does to some extent.
MAXF1net is offline   Reply With Quote
