Old 12-11-2022, 03:36 PM   #1
Hasdrubal
I pulled the entire harness out on my headlights and replaced it wire by wire. I don't have the pin removal tools, so I cut each one and crimped a new section on, then used heat shrink tubing to cover the connector. If you go that route, my main regret is I used the color of wiring I had without any thought on if it would be visible once the lights were put back on the car.
Hasdrubal is offline   Reply With Quote
