Old 12-07-2022, 07:57 PM   #11
elgyqc
elgyqc's Avatar
Are you sure the small chain was offset? The colored links line up with the dimples only at assembly, some chains are not even marked. The dots on the sprockets have to be six links apart.
OK, now I understand. I assumed, for no reason, that the chain length and sprocket sizes meant that those links would always line up with the dimples, not very logical when you think about it. Thanks.
I had to take some parts that were missing from my replacement engine off the broken engine... and have ended up starting to disassemble it. The heads are off and next is splitting the crank case. The heads and cylinders look fine. The videos on youtube by "Man in a garage" are great and I am encouraged to go further. Depending on the condition of the rods and the crank I may even consider putting the engine back together rather than parting it out. I'll post pictures when I see the crank.
Grant
