Old 10-24-2022, 08:20 AM   #11
john12312
2002 Boxster S
If it is the bronze shaft bushing, you have to pull the trans out, strip it apart, and then press in the new bushing before burnishing it to the correct size. Not a whole lot of fun.
Yikes! And I just had the trans out for an IMS, clutch and flywheel refresh. Sounds like it would be an expensive undertaking. I'm inclined to just live with it as it's not leaking onto the garage floor but it's definitely coating some parts underneath. I should probably start changing the tranny fluid every year to make sure it's at the correct level.
2002 Boxster S 6 spd manual Arctic Silver
john12312 is offline   Reply With Quote
