Old 10-20-2022, 06:08 AM   #1
lindemandude
Engine wise the car is pretty much stock with about 90k manual trans.
MAF sensor is below value
O2 heaters are below value
Did an oil change and tuneup a few weeks ago but is unrelated as this issue has happened in previous years (pretty much since I moved).
I’ve tried giving the car gas as well as other changes when starting. Rising in RPM is just the sweep as the car starts. Obviously a normal start would crank, start, rise in RPM, then settle at idle.
Instead of settling to idle the RPM just drops and the car dies. Same result after clearing codes, starting again, gas/brake combinations.
The codes seem largely irrelevant given the same codes have been present long before this issue started happening. Also the fact that the car still starts and drives normally any other time with the same codes still present.
lindemandude is offline   Reply With Quote
