Old 10-18-2022, 10:09 AM   #2
Coaster
Coaster's Avatar
Originally Posted by john12312 View Post
Lots of youtube videos on this. You may not be getting a good ground if you're using the terminal in the fuse box and it doesn't work. I couldn't get a ground on the metal toward the front of the car then tried the chrome metal door latch on the rear side of the body in the driver door opening. Got a ground and the frunk open.
same for me. Had to move ground around a bit to find the sweet spot.
2003 S, 6 Speed, PCM, PSM, Bose, Litronics with washers, on its' second LN IMSB, comfort top, UDP, 987 engine mount, 997 RMS, Koni Sport Shocks, H&R springs, Techno brace, comfort blinkers, nin8six windscreen, particlewave light up cubby
Coaster is offline   Reply With Quote
