Old 10-18-2022, 07:59 AM   #1
FoFoJoe
FoFoJoe
FoFoJoe's Avatar
2001 Boxster for Sale - Utah
Finally selling my baby. I've owned this car since 2016.
Happy to answer any questions.
https://cars.ksl.com/listing/8174368
I am selling my pride and joy for the last 6 years,
my 2001 Porsche Boxster. This car has been extremely special to me over the years. I bought it in 2016 from a family member. The car has been in my family since around 2015 and around 70k miles.
I live in Orem but I can meet anywhere from South Salt Lake
to Payson. Willing to go further on arrangement. I listed the
address as the Orem Walmart.
I could talk for hours about this car, so please reach out
if you have any questions at all. Text preferred and we can set up a time to call and talk about the car.
Overall, she is an absolute blast to drive and has treated
me right since I first bought her.
I am only selling her because I have other vehicles now and
just don't have time to enjoy driving her. I've put very few miles (less than 5k) in the last year.
Here is what has been replaced since I've owned the vehicle.
I used OEM or german brand name parts wherever possible. I have a stack of receipts from PelicanParts from over the years.
I also have a big ole stack of parts that I will throw in. Listed at the bottom.
This is my personal photography portfolio with more high
quality pictures of the car.
https://fofojoe.com/automotive
I am asking $9700 cash.
Reach out via KSL messages or text via my phone number.
360sixninezerosix5six4
MECHANICAL
IMS bearing professionally replaced with the LN
Engineering Kit
De-snorkeled intake
Oil just changed with Mobil-1 full synthetic (receipt
included)
Clutch
Flywheel (factory dual mass)
Slave cylinder
Rear main seal (original was leaking, hasn't leaked a drop
since)
Transmission mounts
Motor mount
NGK Spark plugs and Beru coil packs installed around 15k miles ago
Eibach lowering springs
Front shock mounts, bearing plates, coil spring pads
Sway bar end links and bushings (front and rear)
Full TopSpeedAuto exhaust with new exhaust clamps
Coolant tank cap (newest model)
Water pump (OEM Porsche coolant used, way overpriced)
(receipt included) w/180f thermostat
Serpentine belt
Replaced brake pads/rotors, resealed brake calipers
Alternator rebuilt professionally (receipt included)
Power steering high pressure line
Short Shift Kit w/Function Form shift arm and knob (both
short and long arm included)
Bridgestone RE980AS tires (less than 2k miles on rear)
Carerra III 18x8, 18x10 wheels (off a 2009-12 911)
ECS spacers ( 15mm front, 18mm rear) (extra spacer set included)
ECS extended wheel bolts (original set included)
Front radiators cleaned (bumper removed)
Frunk and trunk struts replaced
ELECTRICAL
Ignition switch
Clutch pedal ignition switch
E-brake switch
Side marker bulbs replaced
Brake light bulbs replaced
LED interior light, frunk light and trunk light
Viper 2 way keyless entry system with 993 keyhead on
factory
key
Bypassed faulty brake pad life sensors
12v dual USB ports, 5v 2amp on switched power direct to
battery
Electric top relay bypass (can retract top in motion with
ebrake switch pressed)
Manual control over front high speed radiator fans via
switch
Full audio system:
Focal Access speakers (165AC in door, ICU100 in dash)
Kenwood BT radio (KDCX701)
Alpine 5 channel amp (PDR-V75)
Custom rear shelf subwoofer box (Pioneer 8”
subwoofers)
Known problems
Turn signal issue
I recently replaced the headlights with well-reviewed LED
headlights. Immediately after I had the following issue.
https://www.youtube.com/watch?v=21uzmrdZk-k
I believe the issue is either in the turn signal stalk or
the headlight wiring. I'll be investigating the issue further but the issue
persisted with the original headlights back in.
Noisy passenger window (still works)
The passenger window creaks when coming up/down but still
works just fine. I believe the window regulator is stretched/needs adjustment.
There are threads on 986forum about this issue and I can elaborate further if
needed.
Washer spray bottle leak
This is a minor issue and I plan on finding the time to fix
this. Basically the lower hose on the washer spray bottle slips off, and I just
need to jack up the car, remove the driver side wheel well and throw a hose
clamp on it. Common issue on these Boxsters.
CEL P0139 and P0159 (post cat O2 sensors)
The car has no cats. I lived in a
county without emissions originally and did not have to pass. Currently the car
is registered registered in Washington State through March 2023. I can
get the car to the emissions "ready" state but I have
not tried passing emissions here in Utah. Willing to talk about this further.
Spare Parts
Spare expansion tank (OEM off a parts car)
OEM wheel bolts (ECS extended bolts are on the car currently)
Spare ECS spacers (can't remember what size)
Full brake pad/rotor set
Spare Function Form extended shift arm
Extra oil pan drain plugs/crush washers
Extra engine and cabin air filters
Master cylinder, pilot bearing
-will update with additional parts, just need to go
through my shop and check again-
2001 Base 2.7l, 5-speed (124k) - LN IMS kit
- TopSpeedAuto exhaust (headers/mid/muffler)
- 997 Carrera III wheels w/ECS spacers 18x8 +15mm/18x10 +18mm, Eibach springs
- FunctionFirst shift knob/short shift kit
- Focal speakers/Alpine amp/Kenwood deck/Pioneer 8" subs
FoFoJoe is offline   Reply With Quote
