Old 11-08-2006, 08:24 AM   #3
RandallNeighbour
The "rings" of which you speak are a molded part of the face of the cluster and cannot be removed. The silver painted aluminum rings you see on eBay are glued over the factory plastic rings.
Here's a link to a page on my site where you can see how it's assembled and how to take it apart.
http://www.iwantaporsche.net/cluster.htm
While it's much cheaper to remove the cluster and mask off the whole thing and paint the plastic gauge surrounds, a much nicer look would be the aluminum rings.
So my recommendation is that you buy some rings off eBay as I did and CAREFULLY superglue them to your cluster with it fully removed from your car. You must use a small amount of thick super glue and be patient while it dries (which is a long time because it's plastic and aluminum and doesn't adhere as quickly as say, two plastic parts would). The best way to do it is to put the cluster face down and then apply the superglue to the inside of the center ring, then bring the center ring upward to the cluster and hold it there until it's dry. Then repeat the process with the left and right rings.
You may also want to swap out the gauge faces while the cluster is out. This, of course, is not a lot more work if you get the needles back in the right position...don't get me started on how frustrating and time consuming that was for me!
