Old 09-24-2022, 06:40 AM   #14
blue62
Luckyman
If I was going through the same issue...since the car runs if you jumper the relay then the problem seems to be voltage supply to the relay.
So I would study wiring diagrams of that side of the voltage supply circuit.
From that possibly I could come up with a plan for testing that circuit out via voltage drop tests.
As JDMsurprise experienced most electrical issues are bad ground issues.
