Old 09-22-2022, 03:19 PM   #1
blue62
Originally Posted by Luckyman01 View Post
However, I replaced about 5K miles ago and the tach needle appears to move (ever slightly) so I dismissed that.
I am however unclear on how much movement I should see out of the tach.
Is there any support for ignition switch theory?
You could test the CPS with a volt meter at the nearest connection by back probing or unplugging the connector and probing the CPS side.
When you crank the engine you will get a signal if the CPS is good.
That way your no longer guessing if the CPS is good or not.
Or I believe you can check the CPS signal with an OBDII reader that has a Porsche program.
Like a Durametric or Foxwell
