Old 09-03-2022, 06:51 PM   #1
911monty
911monty's Avatar
That is the PCV, It opens to vent vapor pressure from the crankcase when engine is shut down . The corrugated hose that the PCV is attached to vents vapors from bank 2 to the AOS. The hose is very brittle and will most likely break when you attempt to replace the PCV if not extremely careful. The hose is a POS to change. Good Luck
PS the leak is actually the round opening above your arrow.
