Originally Posted by KevinH1990
I have an opportunity to buy a set of very slightly used Michelin Pilots. (I'm not sure which model.) The problem is that I don't really need them right now.
How long can a set of tires be stored without suffering age-related deterioration? Also, are there any issues to be concerned with when tires have been take off one set of wheels and mounted on another?
There was a thread on this not long ago. You will want to see if Michelin has a recommendation on these specific tires.
In general, the industry story is unmounted tires shouldn't be used after 6 years. Ten years mounted. But like I said, each tire is different and you'd have to call Michelin.
There's no problem with unmounting and mounting tires 2 or 3 times as long as they're not damaged but again, Michelin would have to tell you specifically how many times the particular tire can be cycled.
