Completed this using a URO rather that a Porshe regulator as I was told that the former is more reliable. The change was not enjoyable but everything is working fine. I should have watched the myriad of YT videos covering this operation much earlier.
There does seem to be little differences between the two. I found that you if you map the original glass position on to the URO the glass sits slight too high when retracted......arrrrrrgh. Not sure if this is due to my marking method. I discovered this once all had been buttoned up
986 00S
