Old 08-04-2022, 04:41 PM   #1
DreamSign
Originally Posted by Boxstard View Post
Input shaft has an oil seal so overfill won’t immediately cause leakage and wet clutch…. But regardless it is specified for reason, and I trust Porsche engineers know how fluid sloshes around when the car is in motion… not logical reason to fill to the plug hole.
Because the 5-spd tranny is from Audi, the hole location was not originally designed for Boxster installation thus the height spec., I guess…. It’s not a big deal to check it, if you can bend and mark a paper clip. Can be done faster than typing up a question here.
Ok, this is exactly why I asked. The hole position was not originally placed for this exact set up.
I will DEFINTELY do the -11mm from the hole.
I'll add the 2.25l and check from there.
Thank you everyone for your inputs :0)
DreamSign is offline   Reply With Quote
