Old 08-04-2022, 08:25 AM   #1
Most_Wanted
ISSIMI
Thanks Start & JFP. Found the intermix while at work & out of convenience decided to bring it to the nearest google 5 star euro shop. Some backstory... Replaced the center rad because of a small leak. Noticed a bit of oil on inlet/outlet pipes. Kinda brushed it off until i saw the coolant reservoir filled with chunks of oil. Checked the dipstick/oilcap, both were clean, no exhaust smoke either. Still expecting a cracked head but hoping for oil cooler being the issue. Then i bring it to the mechanic and instruct him to drain the oil/filter, both were clean. next check oil cooler and that's when we found the coolant passages were intermixing. Now my mechanic is having difficulty finding the right parts...
Most_Wanted is offline   Reply With Quote
