Old 08-02-2022, 07:57 AM   #1
DreamSign
Originally Posted by Quadcammer View Post
are you implying that you are able to generate throttle oversteer in a stock boxster or that you let off the throttle when the car starts to push
My statement was, and I quote "I tend to use the right pedal to reduce the understeer"
The fastest way around a corner is usually the smoothest, so sometimes a little patience with the throttle is the fastest way. Sometimes you have to lift a little to maximize overall speed through the corners. Finesse is faster than wrestling with understeer. A little trail braking can help.
So my answer to your question is: no, not completely, but can come close to throttle induced neutrality.
On offramps where it is easy to test the car at its limits (at least for right hand turns), it showed, as you already know, understeer, a little throttle modulation allows one to transition to neutralish.
The modest 200 hp is plenty under these conditions. The trick is to use most or all of what is available power and grip most or all of the time.
The stock car I find handles close to neutral, it appears the engineers intentionally kept it in the safer understeer range to save idiot drivers from themselves. I think the engineers did an excellent job designing this car.
If one wants, they can change the set up to be more neutral or even some oversteer I suppose...
DreamSign is offline   Reply With Quote
