Old 07-01-2022, 07:59 AM   #1
blue62
Originally Posted by Frodo View Post
That's really helpful, thanks.
So when you replace the round wire type, where do you obtain replacements? Online? Or do AZ, Advanced Auto, O'Reilly, etc just have drawers full of generic clamps that can be used? (I don't know, sounds like you've been around for a while...maybe YOU have drawers full of various generic clamps )
And, if you were doing the coolant tank replacement, with everything so difficult to access, would you still use that approach? (ie reusing the flat spring type?) I just don't want to have to access those clamps twice.
I don't know—maybe you have done the coolant tank. From what I've seen in DIY pictures, it looks like the connections are all that type, the flat spring ones. Did anyone encounter any of the round wire ones in doing their coolant tank?
For replacement clamps any auto parts store should have them. Also Ace hardware carries a small selection.
Another place is any kind of farm equipment supply store.
Yes I have replaced the coolant tank on my 2000-S...... about two years ago.
I reused all the clamps with no issues. They are the flat spring type.
If you have access to a lift that will be the best bet.
It will give you access from above and below.
That is how I did it.
I removed the triangle plate that ties the rear suspension together.
that will give you greater access from below.
Many people on the forum seem to have an issue replacing the triangle plate.
But I think they approach the problem incorrectly it is not really an issue.
You can get to one clamp from the engine bay.
a few from underneath
The remainder by pulling the tank into the trunk area.
If you have an issue just post here on the forum we will get you sorted out.
