Old 06-24-2022, 09:39 PM   #3
Homeoboxter
Ebay, Sunset Porsche, Pelican, etc. But first you need to identify the problem. Open the top and inspect the mechanism that operates the microswitches. When you press the small lever that the hook pushes upward when latching you need to hear two audible clicks. If you hear them try to keep your finger there and see if you can raise the windows. If it works that means that the switch is fine, just something is wrong with the mechanism.
I`m in Mountain view.
Homeoboxter is online now   Reply With Quote
