Old 06-05-2022, 09:39 AM   #16
Stl-986
You dont need 8ga for that amp. 12 or 14ga is more then good enough since you will be mounting it in the stock location and the battery is close. Use 12ga as a safety net, but 14 is also fine. It's only 30amp
Those "amp wiring kits" are generic. They really are to wire up much bigger amps like a 1000w mono amp located 10+ feet from the battery. Send the wiring kit back.
2000 Boxster Tiptronic
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
1986 944 (gone but missed)
