Old 05-26-2022, 08:35 PM   #13
Stl-986
Wait a sec...Do you have the factory amp hooked up to your Avic? If so I'm assuming you are using one of the wiring kits for that.
You wont be able to really do anything with the eq settings. You can make changes on your Avic but it really wont matter with that factory amp in the mix.
In all honesty...you would be better just running the speakers right off your avic. It isn't that hard to do. The wires for the speakers are on the right connector of the amp (when looking it from the front). You can just cut off that amp connector & run extension wires through the firewall to your HU. Your avic has better power then the factory amp and....your ohms would match too as a side benifit.
2000 Boxster Tiptronic
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
1986 944 (gone but missed)
