Old 05-23-2022, 08:07 PM   #13
KevinH1990
KevinH1990's Avatar
If you go with that amp, the sub output from it should go to the doors.
Now you have to be careful though cause your head unit needs to have 6 rca outputs on it if you want to use a 5 channel amp or 4 channel & a separate sub amp. Of course you could also just use Y cables but it is noticeable difference when you do.
According to the installation manual for my AVIC-Z140BH https://www.pioneerelectronics.com/StaticFiles/Manuals/Car/AVIC-Z140BH_InstallationManual011612.pdf I have a left and right subwoofer output. It appears that I am in good shape for adding an amp to power two woofers.
I think I will install the wiring (two RCA cables and splice into the amp turn on wire) when I fix the vent foam issue next weekend. (I checked the video on accessing the dampers through the cowl, but it looks I would risk breaking a lot of potentially brittle plastic parts.). Then I will hint about the amplifier for a Father’s Day gift.
