Old 11-06-2006, 12:56 PM   #2
RandallNeighbour
Subgraphic, I am sure you could get them to fit your boxster providing you had the right spacers on your car... but they're awfully wide and will probably rub in the front for sure and possibly the rears when under heavy loads (rubbing the top fender).
The secondary issue is that of your wheel bearings and the fact that these much larger, wider wheels may cause premature failure with 1.5 inch spacers on the back, for example.
The third and final issue to consider is the price. I'm betting a set of these rims are no less than $3500 at Sunset, the cheapest place in the US to buy OEM Porsche parts.
I have seen some nice aftermarket sets in ads in Excellence that look a lot like these rims. That may be a better way to go.
