Old 04-26-2022, 10:35 PM   #13
Smallblock454
Seems like the mechanism is put together with Torx screws. I would open that thing and inspect everything.
Your description sounds like the is a bad solder connection or a bad or corroded contact. So i would inspect the wiring, the contacts and the solder points. Of course it can also be a bad micro switch.
If you have Piwis or Durametric you can check the M535 for DTCs so you know exactly what causes the double beep of the alarm horn.
