Old 04-10-2022, 03:12 PM   #1
ike84
Originally Posted by wwjd View Post
I did some searches, but I am wondering if there are any good, no mod needed, drop right in, good LED bulbs to replace the standard H7 headlamps?
Found a bunch on amazon, and even walmart, but wondered if others have already sorted this option out successfully?
or poste related thread if I missed in my searches thanks!
I have Firehawk in my low beams and acuma in my high beams. Install is a bit of a trick because the retaining latch won't seat over bulb base. You must remove the retaining latch, position it around the bulb base, install the light, and then reseat the retaining latch. You'll understand what I mean when you do it. Other than that though there is no modification necessary and I really like them. They absolutely have their drawbacks (light pattern, cri, etc), but the new ones are far better than the first generation.
Sent from my SM-G970U1 using Tapatalk
