Old 04-06-2022, 08:21 AM   #13
FoFoJoe
FoFoJoe
FoFoJoe's Avatar
I would also swap the coils. I had basically the same issue and symptoms you described 2 summers ago. Although my issue started on it's own, I hadn't swapped the plugs before.
Here is the kit I used. NGK plugs and Beru coils. No issues since.
https://www.ecstuning.com/b-assembled-by-ecs-parts/ignition-service-kit/99760210700ikt2/
60k miles and 20 years of service isn't bad for factory coils.
Also when you swapped the spark plug tubes what tool did you use?
I used a transom boat plug, 1" lol. Wrapped it in electrical tape and plucked all the oil tubes out perfectly.
2001 Base 2.7l, 5-speed (124k) - LN IMS kit
- TopSpeedAuto exhaust (headers/mid/muffler)
- 997 Carrera III wheels w/ECS spacers 18x8 +15mm/18x10 +18mm, Eibach springs
- FunctionFirst shift knob/short shift kit
- Focal speakers/Alpine amp/Kenwood deck/Pioneer 8" subs
FoFoJoe is offline   Reply With Quote
