Old 04-03-2022, 01:35 PM   #1
elgyqc
elgyqc's Avatar
I would doubt that the problem is that the plugs are not Bosch. Much more likely, as suggested by STL-986, one or more coils are not properly seated on the plugs or that a coil wire is not properly inserted all the way into the connector, they can be difficult and if you don't pull the rubber boot back you can't see if it is not seated.
Grant
