Old 03-17-2022, 09:53 AM   #14
howdy
why for the love of Pete would you want to use a part that has known failures?
Especially when there are several better choices available
Taking "the solution" out of the equation, what better choices are there? The LN retrofit has had failures as most have seen, so its certainly not perfect. Have seen one EPS failure up to this point and many people are to installing them. Not a fan of the Pelican/LN single row bearing and having to use spacers. What are you other better choices that you speak of? DOF? MB?
The stock bearing has held up fine for 21 years and 85,000 miles. I just removed it and that was probably premature considering the condition it was in. I would not be scared to put another one in there with the dust seals removed and let it run.
howdy is offline   Reply With Quote
